TwinTurbo.NET: Nissan 300ZX forum - You might be mistaking an exhaust leak for knock (n/m)
Greg D. (Specialty-Z)
on June 25, 2015 at 12:53 PM
Detonation at low boost (long)
posted by RBTT
on June 23, 2015 at 09:58 PM
RBTT
21:58:13 06/23/15
How much boost are you running?
Stanky
00:35:04 06/24/15
Re: How much boost are you running?
RBTT
02:00:20 06/24/15
Did the detonation start right after you installed the
SirpriZ
12:21:42 06/24/15
I have stock piping. Although I'm not sure which
RBTT
17:49:13 06/24/15
I'm sorry, that info must of sounded psychotic. I read your
SirpriZ
14:40:03 06/25/15
I'm trying (poorly) to reference what might be happening
SirpriZ
17:51:16 06/24/15
a couple fuel system suggestions:
shaggee
12:43:13 06/24/15
You say "low boost", and "any time the boost was higher
zellamay
14:24:05 06/24/15
It's happening under light throttle. Basically
RBTT
17:47:42 06/24/15
Also, the big clue might be "until recently". It might be
zellamay
14:28:14 06/24/15
Do you have a after market water temp gauge, check the
njz
15:37:18 06/24/15
I only have the stock gauge. Do you mean to check
RBTT
17:50:31 06/24/15
check oil level (n/m)
njz
20:44:19 06/24/15
Check EGR from the EGRC solenoid (red line) on P.S.!!
OverZealous (CT)
18:15:23 06/24/15
Ok, thanks. I will check that in a week.
RBTT
22:34:03 06/24/15
Really? 3 times? Sorry (n/m)
RBTT
01:25:00 06/25/15
You can delete the other two. (n/m)
zellamay
08:03:43 06/25/15
You might be mistaking an exhaust leak for knock (n/m) -
12:53:28 06/25/15
Maybe. But it only happens under boost It
RBTT
19:38:10 06/26/15
